Short question considering 2012 Boss 302 grille & fog light covers
Dear forum,
I do not have the 2012 manual for my car, but the 2013 manual I got as pdf tells me to remove the fog light covers for track days.
The thing is that in my grille, the are not removable. The grille is cast in one piece.
Are they only removable on the 2013 Boss? Or does that mean I do not have an original grille? I do know the car had quite an accident and was imported to Europe as a crashed car and was repaired here.
Thank you for your help!
Oliver aka Tomcat0815
They only come out on the '13s. You probably have an OEM Ford part, but there are reproduction parts out there.
Welcome to TMO! I don't think I said so earlier. Nice to see more Bosses across the pond. :)
I am pretty happy with the car so far. I had an BMW E46 M3 before that and I was not expecting the Boss 302 to perform so well even before I had any mods installed. Which probably tells more about my driving abilities than about the two cars...
But about the grille, what's the way to go here? Should I cut out the fog light covers with a Dremel and epoxy in some black mesh, 302S style?
Or should I just remove the whole grille and replace it with chicken wire or whatever when I am on track?
@TMSBOSS I'm sure there are, but having them sent to Germany and paying customs and taxes means that parts like these usually cost double than what they cost in the US.
I'll check out the Cobra Jet grill nonetheless, thank you!
The 302S mesh is wired in. The mesh is coated 1/2" square. I wouldn't use epoxy but should work okay if you make sure to have good surface roughness for mechanical bond. Wire method seems safer to me.
302BOB
Epic Contributor
I have a '12 Boss and I drilled my Faux fog lites out using a 5/16" drill bit...The first one is the hardest...went quick after that...;)...I liked the look after I was done..........
Welcome! I bought a cheap 7 bar insert from American Muscle (I think it was $55 or so) then purchased a Grille surround from Rock auto for $50 and made my own cheap grill (looks to me like a Roush). Let's in a ton of air and I can swap back in the stock grille for that look for the street. Just another cheap option for you. It certainly gets A LOT more air in the engine bay. If you look closely, the stock boss 2012 grille has a lot of the areas blocked off, very little air flow.
So back in the day, (2012) Ford Racing came out with a 2012 Boss 302R front grill to improve air flow and of course I order it for something like $300USD.
Here is what I got: A stock or production Boss 302 grill that they cut off the back of the faux fog lights to open it up & then they installed a 1/2” coated wire mesh that was wired into 8 drilled holes on each opening. When I say “wired in” I mean like safety wire(ed) in. It works & I came to actually like it.
Maximize the air flow by cutting out the fog light plug. It also greatly improves the air flow to the air cleaner cold air box.
Save yourself some cash or Euros and DIY it. Just another thought.
