- 899
- 548
I am using Gen 1 timing components and engine management. I was able to get a set of some of the last Ford Performance cams for the GT350 heads that are designed for Gen 1 timing components and engine controls. SteveEspo has a 2018, so he will simply have his tune updated.
At this point for Gen 1 / Gen 2 cars, I would either use Boss or Gen 2 heads with a stock Boss or Gen 2 exhaust cam and L&M intake cam. I suspect you could make similar horsepower, but more important is the mid-range torque for corner exit, especially when you are trying to fit into a class like NASA ST2. In my opinion, for an ST2 or similar car this type of build helps increase mid-range torque and then you throttle blade tune the top end to match your average power to weight cap.
At my current weight, I can only get away with something in the area of 475 - 480 average HP based on NASA ST2 calculations with a 315 Hoosier. If you look at the above graphs for the 5.2L, I can throttle blade tune the engine and hold a flat 475 - 480 HP from 6200 through 8,000 (where the current limiter is set). In other words, the only time I would see a drop in horsepower is at corner exit (3,500 - 4,500 rpm) which is where the increased mid-range torque comes into play. Other than corner exit, my HP would absolutely constant.
