S197 3V Upgrading 2006 GT to EPAS
I'm digging into my endurance racing project car and one of the first things I knew I needed to do is replace the leaking power steering pump. When I got under the car and did a detailed examination I noticed that the hydraulic steering rack has a bit of play in it on the driver's side, plus every boot was torn or loose, so I'm thinking I'm better off replacing the steering rack. This, plus the need to add a power steering system cooler and a new pump, would make the conversion to an EPAS system almost cost efficient!
Reading through several threads on here, it sounds like the ticket is to get the BOSS 302R rack (M-3200-EPAS) as that avoids the troublesome anti-nibble programming in the other versions. Then all I need is the "stimulator" from Cortex to get it to power on. Is it really that easy? Is there anything else I'm missing?
Thanks!
Rick at Cortex was quite helpful. In addition to the Boss 302R rack and their EPAS stimulator, the k-member needs to be changed because the 2005–2010s have only two holes for the rack, while the 2011+ k-members have the three holes needed for the EPAS rack. An OEM k-member from a 2011 thru 2014 Mustang will work, or several of the aftermarket ones will work as well.
Unfortunately, Cortex is out of the stimulators because a key supplier can't provide the chip they use. They're looking for alternate suppliers, but as of now they don't know when they'll have more stimulators for sale.
I'm trying to have the car ready for a June track day, so I think at this time I'm going to just replace the hydraulic components and save the EPAS upgrade for a later day.
Also, I found a very interesting link from a company called RaceCar Services. They make a wiring harness that lets you connect an EPAS rack into the CAN bus of a 2005–2010. This lets the rack access all the data on the bus that a simple stimulator doesn't provide, thus allowing the EPAS to provide variable assist. Something to think about in the future…
I’m in the middle of this process on my 06 as well. Unfortunately there are no new boss302s racks to be had at present. I bought a simulator and ordered a 2013-14 rack from a junk yard to get me by until the boss units are available again.
Steeda's website claims they have fewer than five in stock…
I'd be surprised if they actually do have them....but its possible they had some stashed.
Ford currently has none.
Okay, good news and bad news...
First the bad news:
They only had one in stock and its gone.
Now for the good news:
It's gone because I bought it.
Thanks for the heads up....
Okay, update.
I tested at Sonoma and so far the epas rack has been fine.
I will be racing at Thunderhill and Sonoma back to back and will pay more attention to the precise feel of the rack, but so far its been all good.
Stay tuned.
Okay, update.
Stay tuned.
Just as an update, the boss 302r epas rack has been great, trouble free and the feel is very good. Worth the investment in my opinion.
