Wheel/Tire Fitment
I have 18x10 SVE Drifts and though I'm sure most know I'll post the details: offest is +43mm and backspacing is 7.2in. I'm wondering if the Nitto NT01 305 35 18s would fit for a square setup? Car is 2013 Boss LS with stock suspension except I do have MM CC plates at max negative camber. I've thought about cutting the end link bolt that point out at the tire if needed.
Thanks
5,261
4,259
It should fit but you might want a 1/4" spacer or similar up front to optimize strut to wheel clearance
Sent from my iPhone using Tapatalk Pro
I can confirm, My previous set up was 18x10 drifts with P springs and 305/35-18 nittos, fit fine but with out a small spacer they would rub on the brake ducts.
Do you recall which size spacer you used? I have 1/8" spacers on hand now. Just need to figure out if I should buy 1/4" spacers.
