- 899
- 547
Justin said:hmm good question ill have to check
What is the shifting like post insert modification?
thanks!
to me it feels the same but I also have2012-Boss said:What is the shifting like post insert modification?
thanks!
Justin said:to me it feels the same but I also have
BBR motor mounts and MGW shifter.
if its better then it was its just slightly then without. mine might have been so bad because I already have the stiff motor mounts. The motor mounts made a huge difference with just a slight increase in start up vibration. though its a much more expensive and harder mod to install.2012-Boss said:The same as in no difference when compared to no insert or even post-mod it improved shifting?
thanks again,
roadhouse said:Sounds like good feedback so far, looking forward to trying this out. I ordered one a few days ago but it won't ship out for awhile.
Voltwings said:However, after a few hundered miles, the NVH settles down significantly and you end up with a softer, yet still more firm ride.
tlflow said:it made a noticeable improvement. When I am right up against the redline, it's still a bit iffy. I mat the clutch (all the way) it's better, but when I get sloppy and it will hang.
Buzzes my right butt cheek ... anybody that says these aren't noisy is FOS (or deaf and has a numb ass).
I got a MGW on the way and will be getting a torque brace too:
http://www.cheperformance.com/prod-208.htm
tlflow said:After I installed the MGW shifter there is less noise and vibration? No idea why, maybe the factory shifter was buzzing. I need to retract my statement above.
The MGW makes me happy happy happy
