Now that Ford is offering a set of camber plates for the GT350 and R, the alignment settings in the 2019 GT350 Owner's Supplement (see link below) are slightly different:
GT350
Front
Camber -2.00°
Caster 6.81°
Toe - Total 0.10° toe in
Rear
Camber -2.20°
Toe - Total 0.30° toe in
GT350R
Front
Camber -2.20°
Caster 6.92°
Rear
Camber -1.60°
Track Tire Pressures:
Cold Tire Pressures GT350 and GT350R
Front: 28 psi (1.93 bar)
Hot Tire Pressures GT350 and GT350R
Front: 38 psi (2.62 bar)
Rear: 36 psi (2.48 bar)
Link to the Owner's Supplement: http://www.fordservicecontent.com/F...350-Supplement-version-1_sg_EN-US_12_2018.pdf
GT350
Front
Camber -2.00°
Caster 6.81°
Rear
Camber -2.20°
GT350R
Front
Camber -2.20°
Caster 6.92°
Rear
Camber -1.60°
Rear:
28 psi (1.93 bar)Hot Tire Pressures GT350 and GT350R
