- 6,405
- 8,301
Google Marshall Mast / SCCA if you don't think stock 3 valves won't run..
Adding Apex 18x11" EC-7 wheels in satin black to the list of things piling up in storage for me to play with.
Yes, precisely.
You and me both. Unfortunately, as I am currently in the faraway land of Nippon, all of the stuff I buy goes straight into storage alongside the car until I return to the glorious Homeland in approximately 1.5 years.Must. Pictures. Now.... please...
Looking at your list of mods, I'm hoping to see offset struts or wheel flares sometime in your future. These wheels will poke about an inch and require lots of camber to fit. Do you have a game plan or something in place to make the 11" wide wheels work?
Glad to see you've got it covered. I'm a little jealous of the 315mm setup. You should be OK with clearances if the offset is around 52mm or so.
I’m just getting going on my 3v build that I hope to drive soon.
I’ve read some guys saying stay away from bracing as it’s not needed. How is the Che k member brace?
I bought that to try and clean up shifting a bit, not for any additional chassis bracing. I honestly couldn't say if it helped and plan to toss it in favor of the OEM Ford k-brace and a Blowfish Racing bracket to take care of the sloppy shifting.
Additional bracing is not necessary, except maybe where Ford added OEM bracing, and even then I doubt most people can really tell the difference.
Be sure to start a build thread so us 3v stepchildren can follow along! I'm compiling a list of threads on here that are specific to 3vs.
