764
1,144
TX
Welp, I couldn't handle the rats nest my original PDM/ECU layout created trying to get all the circuits integrated and ran through the bulkhead. After a couple of weeks of trying to get over it, I gave in to the inevitable and ripped it out and moved the PDM/ECU behind the passenger seat. Not seen is a plate the electronics sit so they can come out as a unit.
About 75% done with the new wiring harnesses that integrate with the rest of the car. Just waiting on two boots and then I can pin and reinstall the bulkheads
Also finally quit procrastinating and got to work on the rear bulkhead. This sucker has been TEDIOUSIMG_2644.JPG
1,250
1,244
In the V6L
Also finally quit procrastinating and got to work on the rear bulkhead. This sucker has been TEDIOUSView attachment 94356
With the electronics on the floor, could rain become a problem?
764
1,144
TX
I don't think so. They technically float about 1in off the floor pan and I've never had an issue with water pooling there - even in some pretty wet conditions. The electronics are also IP water resistant, so should be good. But we'll see3BC31C91-32DA-4B9F-BD0A-3C5D95D3B88A.jpg
630
1,071
Wisconsin
I just installed this one https://competitionmotorsport.com/c...zero-360-fia-3-0kg-novec-1230-electric-system
Electrically triggered - can put buttons to trigger any where - only two wires. Super easy install and this foam won't corrode your interior/engine bay and ruin everything if you need to deploy.
I also added this to trigger if I am ever passed out and the car is burning https://www.bimmerworld.com/Safety-...feline-Protectowire-Heat-Detection-Cable.html
Thank you, ordered that one as well.
764
1,144
TX
What’s the aero package looking like? Still going with the active aero?
Not a whole lot different than where I was before tear down except for an added rear diffuser and ducted/sloped radiator up front. Longer term, will add a bigger splitter with tunnels and the active wing in the back for some DRS :)
1,250
1,244
In the V6L
I don't think so. They technically float about 1in off the floor pan and I've never had an issue with water pooling there - even in some pretty wet conditions. The electronics are also IP water resistant, so should be good. But we'll seeView attachment 94367
That's great, but with all the cutting and chopping you've done to the chassis since the picture was taken, are there possibly new pathways for water to get in? If you have room to mount the electronics 2" off the floor, it might be worth it.
764
1,144
TX
Anything is possible, but I really don't think so. I've actually closed up more holes/gaps than before--been placing a special amount of attention to fix areas that debris can get in the car.
Don't think I can lift them higher - the wires need to run under the seat and things are a tight fit. But we'll see what happens. I am not worried about it - everything is sealed and weather-resistant and it's not like the car sits outside. It's spent more time on a lift than on the ground at this point 🤣
764
1,144
TX
Custom front crash bar/tow hook setup is complete. Bar is right up against the bumper, maximizing clearance to the radiator for the future ducting. Not the most meticulously fabricated piece, but it should be plenty strong and super functional.
I have the wiring 98% buttoned up - just need to document final install. Also got the new pedal box in - just working on some plumbing changes now. Will share more details tonight/tomorrow AM.
Getting closer to first start and (hopefully) test drive!
6,556
8,207
what air cleaner is that?
764
1,144
TX
764
1,144
TX
More progress. The wiring is done. Just need to start the car and verify before I heat shrink the remaining boots. Will take pics tonight after I clean up the mess I made yesterday chasing a few pins/sockets that had been swapped.
I did relocate the reservoir tank to the cage for easy access/checking. No spillage in the car and still out of the way.
The only thing left is some clean up on the pedal box and she's ready to start. Still waiting on the base tune and getting scheduled at the dyno. Really hope to fire it up this week/weekend. We'll see.
37
24
Wyoming
Best thoughts going to you. My selfish is seeing your often parallel development, but literal mountains more personal labor and dedicated racing effort, to get insight into my car.
My set up is custom cross plane, Dailey dry sump, MoTeC management but retaining OE can-bus chassis electronics. All still in progress. Will I be able to use the “Track Mode” least intrusive settings to really let my new engine sing? I’ll have a 9000 redline, ITB responsive, switchable 500-700 hp dream to unleash. My decision to do the expensive engine before big chassis modification stemmed from my battle with the oil filter spinning off the way too vibe happy 93mm stroke flat plane crank. My car will still be streetable and for another good 50k miles hopefully.
GT3 and GT4 aspirations coming if I ever recover financially.
764
1,144
TX
Got the wiring buttoned up last night and happy with how everything came out considering it's me. I'll do an in-depth overview video of what's what and how they all integrate in a future overview video. Running like mad to get the car fired this week
445
590
Wisconsin
Still above my pay grade, nice work Kevin !! Hope to see the badger out at a track someday.
764
1,144
TX
I was down all weekend with a monster migraine that came out of nowhere - so lost a few days. But got back at it on Monday after work as was able to make some headway.
I finally finished up the pedal box install. As mentioned in a previous post, I upgraded to the Tilton 850 series underfoot pedal setup for two reasons - one, the 76 series master cylinders that are used on the 600 series I bought are not "recommended" for use with ABS systems. Either that wasn't on the listing when I bought the pedal kit a year or two ago or I missed it completely (probably the latter). Second, I never could find a way to make it fit with a pedal cover/false floor like I wanted. Here's a picture of the original 600 Series install (ignore the Deutsch connectors - they had just fallen from above).
While it doesn't look too bad in that photo - the truth was the OEM gas pedal was constantly hitting the foot well pan and the much bigger issue was that to get it to fit like that required a gap of 2-3 inches underneath it.
This is the best photo I can find showing what i mean
This is much "lift" above the floor was required to make it work. Really didn't like the result
Here's the new setup. Much cleaner, I think. Plus, the pedals feels better :)
Lastly on the brake front - I changed out the OEM connectors going to the wheel speed sensors some autosports. The boots provide much better strain relief as well a more reliable connection.
And lastly for tonight - I got a bit further on the rear bulkhead/firewall. Hopefully can finish up tomorrow or Thursday.
Still waiting on a tune to fire the car. The weight is killing me. Sigh
