2011 just turned 90k. I have had it for about 15k and recently noticed the following:
Cold start, no issue. Driving creates an rpm based tick/rattle from around 2k-3k. Similar to the sound of a sewing machine. Most apparent when cold, never noticed it during the summer. Happens at low load. Tipping in the throttle seems to make it go away. Also the noise diminishes as the oil heats up. I am on Castrol Edge 5w40 now. The sound may have been there the whole time as I recently switched to the stock mufflers. Interior is very quiet now.
Did the searching. Found BBQ tick, piston slap, rod bearings, timing chain issues and VVT issues. The last seems closest to what I have. Oil pressure issues create a noise from the VVT system? Its an early 2011, so maybe needs a timing chain set? Different oil?
Let me know what you think. Appreciate the help...
