- Thread starter
- #41
Yeah I was trying to get on throttle as early as possible that was certainly tough lol. I think I do need the electronic bypass valve for the whipple someone mentioned here. The 11-14 pedal also seems more numb than the 05-09. Maybe its just the tune though I can talk to Joe goodnough. I do also suffer from cave man syndrome of just wanting to push the pedal and over the years I have gotten better its just hard not to want to just hear the freedom pedal lol.LOL, I love that whine when you are on the throttle!
But you gotta go easier on the throttle until you get the steering wheel straight, lol.
The braking video was scary. No ABS on this set up? You did a very good job catching the car and keeping anything bad from happening.
So here is a question, if you know yet, how many laps can you get before oil or coolant or CHT gets too hot?
It does have stock ABS which sucks. When I swapped it I lost comms with the module so I bled it the hard way, which wasn't enough I guess. I need an aftermarket system or at least a manual way to do the dealer abs purge. I could also just use my old ecu but that is just as much as a pain. I ordered new wheel speed sensors just incase though too. After I bled it at the track though it was pretty much fine. I've had this problem before when I accidentally get air in the abs.
Anywho temps were tough this weekend it was around 87-92 thurs-sat and 70s on sunday when the sprint was. I could do the whole 15min session fine with it being 70 but could do 2 hot laps when it was hot. I dont have oil temp but 2 oil pressure gauges, one is a fancy Texas instruments one thats connected to my obd2 haltech you can see in the vid. I set upper and lower warnings on all the stuff there. I mostly just come off if I get iat over 145. The other gauge is my old autometer ford gauge thats connected to the tstat side of the oil cooler. Its not as reliable and is hard mounted vs soft but I figured id just leave it.
