New Clutch Installed, Now Won’t Go Easily Into Gear At Start-Up
My Gt500 pulled this, after pumping the pedal about a thousand times and vacuum bleeding it a dozen more, it would still go into gear hard in the mornings. I would start it in gear and it would try to creep. It eventually went away with more vacuum bleeding and use. I wouldn't take it back apart just yet. This is one of the many issues with hydraulic clutches, air bubbles, difficult to power shift, no adjustability. Clutch activation technology was at its zenith with the quadrant style cable clutches of the 90s.
My Clutch does this after 2-3 track days when there is too much air from overheating the brakes usually a fluid change gets rid of it.
I tried leaving the clutch depressed with the drivers side elevated over night then pumped the clutch a couple hundred times to no avail. It's been about 1k miles since clutch swap. Drives fine otherwise. Just when I go from a stop into 1st or reverse get locked out unless I hold the pedal down for several seconds or go into 5th first or something...
Stack up height may be short. We have to use a spacer on Exedy clutches to get correct throw to fully release. May be the same in your case. The TOB has a 7/16"-1/2" throw. Measure block face to clutch fingers, then Bellhousing face to un compressed TOB bearing. The difference will be the compressed installed height. If it is more than 1/2" then the bearing cannot release the clutch fully and will most likely over extend and blow out. Ask me how I know. Also if it is just a bleed condition (which is possible if the TOB was not bench bled prior to install, then you need to put vacuum on it and let it hold for a few hours. -16" of Vacuum max. Then pump once, release the vacuum, pump again 10-20 times and put vacuum on again for a minute. Should get the air out.
This just happened to me again, today. I started the car and it was stuck in gear,instead of just wrenching the Trans out of gear and possibly bending something,I shut the car off, gave the clutch a couple of pumps, restarted the car and it came right out of gear. This clutch has been in the car for about 10K miles, bled a thousand times etc.... etc, it's just a crappy design.
This is different your brakes check valve is broken. Car is losing vacuum when staying a few days. It's like a 10$ part so annoying.
So I am having this problem with an excedy mach 600 clutch and their lightweight steel flywheel. I have a divorced resivoir and mcload stainless braided clutch line... The kit came with a new slave and bearing. I have warrantied the slave on excedys recommendation and the shop has bench bled and vaccume bled it several times on top of it being driven about 1k miles then they tried to add a shim to clutch bc it was engaging near the bottom and still did not fix the issue. To describe in detail the problem for several seconds the clutch won't release from a stop hold it on for a while and it will let you put it into gear and it has no issues driving otherwise... The shop is out of ideas and wants to try a different clutch. Any help would be greatly appreciated. Idk what to do...
