VMP Coolant Tank
63
54
St Louis, MO
Anyone rockin one of these yet?
I run water so I wanted to bump the pressure, need a standard cap and overflow for that, so went with a Canton aluminum unit, and it fits perfectly where the battery was!
The VMP is on sale right now $50 off. Guessing Labor Day sale. That was enough to push me over the edge and order one.
Thanks guys! I'm a bit of a detail nut. It's my first true passion. Since the tank does have threaded fittings for the two small coolant lines, I may touch those up a bit and swap them out for some AN fittings and braided lines. Get rid of those clamps staring me in the face.
One other really nice touch on this tank is they added one of those snap type fittings on that 1" coolant hose that's on the bottom of the tank. It's a similar type snap on fitting very similar to what you see on the PCV and other connections. Makes removing the tank for whatever reason super clean and simple. No hose clamp and twisting to get that hose off the bottom.
