- Thread starter
- #41
Should add this is with the fuel needle right on half a tank, which is about where I'm at when I go out for time attack sessions3600 lbs dry is pretty darn good my friend!
Can you do a short review of the R8 and compare it to other tires you have used?if only hoosier made the R8 in a 295/35
In a word: FastCan you do a short review of the R8 and compare it to other tires you have used?
I'm late to the party but how hard was this install ? I'm thinking of upgrading my pump to a KPM because my local track now has a high speed long left hand corner in which If I'm down on fuel the car starves. Do you think a dealership will be able to do a KPM install ?Installed the KPM 800hp fuel pump. Just did a simple drop in and go. The car acts and feels the same, AFR's are all the same. STFT's are pretty far negative as I think it's supplying more fuel than its expecting, but KPM told me over several drive cycles it should learn and adjust.
Install video is third one down.I'm late to the party but how hard was this install ? I'm thinking of upgrading my pump to a KPM because my local track now has a high speed long left hand corner in which If I'm down on fuel the car starves. Do you think a dealership will be able to do a KPM install ?
kpmfuelsystems.comThat sounds very close to the time difference of moving from track tires to racing slicks.In a word: Fast
Before the Hoosiers I ran a Toyo R, and from the drivers seat the Toyo R felt good to me, consistent and smooth breakaway, but the stopwatch never agreed. I ran about the same times that I would run with the Bridgestone RE71's before. The Hoosier needs to be brought up to temp slower but once its there the grip is unreal compared to what I've ran before.
This summer offseason I made the switch to using 2 sets of wheels: a 19x10 LMR/SVE set that were my street wheels now have 295/35/19 RE71RS's that are my tires for HPDE, and the Hoosier R8 is on my 18" Apex wheels for when the stopwatch comes out in Time Attack (I don't want to burn up $2500 rubber in HPDE)
My first weekend running the Hoosiers I was about 3 seconds quicker than the Bridgestones (both brand new stickers) at Inde- a 2.75 mile track (1:55 vs 1:58). This past weekend they were about 2 seconds quicker than the RE71's at a short 1.1mile track(1:04 vs 1:06) before the rain came
It's an easy DIY project, get the lock-ring tool, it's a life saver and makes the job a breeze. Run a dedicated filter, KPM offers their own plug-N-play model but I opted for a larger Radium 6-micron glass-fiber filter to better protect the direct injection system used on Gen 3 Coyote. If you're not comfortable with the DIY approach, a dealer or independent shop could easily do it, like any OEM install, just be sure to have a near-empty tank so they don't make a mess removing the old pump.I'm late to the party but how hard was this install ? I'm thinking of upgrading my pump to a KPM because my local track now has a high speed long left hand corner in which If I'm down on fuel the car starves. Do you think a dealership will be able to do a KPM install ?
Sadly I'm not very mechanically inclined which is the political way to say that I have 2 left hands. So I just wonder if a Ford Dealership will be able to do that. The near empty tank suggestion is a great one though.It's an easy DIY project, get the lock-ring tool, it's a life saver and makes the job a breeze. Run a dedicated filter, KPM offers their own plug-N-play model but I opted for a larger Radium 6-micron glass-fiber filter to better protect the direct injection system used on Gen 3 Coyote. If you're not comfortable with the DIY approach, a dealer or independent shop could easily do it, like any OEM install, just be sure to have a near-empty tank so they don't make a mess removing the old pump.
Yes it was easy, have them do a KAM reset too, just tells the car to relearn its fuel trims and take it for a few normal drive cycles.I'm late to the party but how hard was this install ? I'm thinking of upgrading my pump to a KPM because my local track now has a high speed long left hand corner in which If I'm down on fuel the car starves. Do you think a dealership will be able to do a KPM install ?
I used this one. Fit perfectly
This one is surprisingly detailed as a "how to." Although it appears that he starts with the back seat removed, he clearly shows you how to remove it, which is easier explained with the seat out than with the seat installed, where you cannot see where the clips go into the floor or how the hole in the floor is shaped. By seeing it with the seat removed, and him showing you with his fingers how to push, it is easier to understand what you must do.
Watch the entire video, and then decide. Getting the tool John S. mentioned probably makes it even easier than the screwdriver and hammer method I the video.
