2024+ Mustang Brake Pads Available NOW
New Product Alert: 2024+ Mustang
We have G-LOC Brakes Brake Pads available on our website for order.
These fit ALL 2024+ Brembo Brake Package Mustangs - GT Performance Pack - Dark Horse
If your 2024+ Mustang has 4 Piston Rear Calipers, you have the Brembo Brake Package.
We currently have them on order and we should be shipping them soon. They are a departure from any other pad so they are unique shapes.
We will stock them in our typical compounds, Street and Track Use.
Let's talk about OP Mustang and what kind of people Tim and Kelly are.
As many of you know from Facebook posts, I suffered another engine failure due to a secondary cam timing chain failure on the right bank of my engine. This caused piston to valve contact on the intake side and broke 5 rocker arms and the number 5 cam cap exploded. The result was a scored intake cam that I was planning to reuse on a replacement long block. Well Tim saw the post and pictures and immediately emailed me to provide the specs so he could contact Comp Cams. I had tried to contact them earlier but was on hold for 1 hour before I gave up and hung up. Tim who has the secret Bat Phone connection was able to get in touch and also was able to get them to sell just the cam needed for my set. Now I did not buy these cams from Tim but as a strong presence here at TMO for many years, and a good friend of mine going on 8 or 9 years he used his connections to help a fellow Mustang racer. Comp said the cam would ship in 3-4 weeks, but this morning Tim emailed me that they were packaging it and preparing for shipment to me in a couple days. The small vendors such as OP Mustang and many others are one of the reasons grassroots Mustang racers like us can get the latest race level parts and participate in research and development of new improved items that are track focused and not just some bling bling carbon applique'. So when you need that new set of pads or rotors, give OPMustang.com a look and order some stuff, and if it is something else they don't advertise give them an email or call and they will steer you in the right direction to find what you need. They are the kind of people that will help a fellow enthusiast in need, even if they don't make the sale themselves.
Thanks very much,
Thanks very much,
Another engine failure. When did that happen? Oh and I always call Tim first fir brake pads and rotors.
Thanks Tim! Any 2 pcs rotors on the horizon for the 2024? Curious if the hats will be the same S550 vs S650 but with different rings to accommodate the swept area differences.
For giggles I test fitted a DH caliper on my Mach 1, offset was same but pads overhung the rotors at both inner and outer dia.
Oh we have Girodisc on that, they already have them modeled from our samples. Huge weight savings in the rear, the DH has an aluminum hat already but Ford is really proud of them making the Girodiscs very cost competitive. You will see a bigger savings on the Brembo package cars with an iron rotor up front.
Girodisc is sending us some 3d models to verify fitment/clearance. Hope to have the production pieces this summer. The 2024 brake pad sales have picked up a bunch which tells me real people are actually buying the cars. Cortex has pretty much sorted the differences on the suspension from thr 550's so plenty or support for the platform already.
...........and that folk's is why Tim should be your go to guy for G-Locs as my little question didn't even need to be asked as he always gets them pre-bedded. I was a small Dealer for them years back and we always did like Tim and most Dealers do not.
Tim is wise and just knowing that little bit of info is why you should only get your G-Locs from him.
FYI: Just got R-10 G-locs and they are not bedded. Also, no one seems to know if I need to transfer the shim from the OEM rear pads to the new ones that didn't come with any. I was able to pry one off without destroying it. It probably should go on the new ones, but I'm wondering what adhesive Ford used that stands up to the heat. I'm doubting that it can free-float in there.
Did you get these from OPMustang or some other source? I have suggested to all my friends to go with Tim as there are other distributors that do not pre-bed just to show a lower price. With experience with Carbotech going back to 2006 and G-Loc from the beginning of their Company, both pads should be pre-bedded and I would only recommend an R10 to go on the rear.........Mustangs are too heavy for aggressive driving with anything less imho. That said, a R10 up front on a car that just autocrosses is fine.
I got them from Steeda. I ended up calling G-loc today and was told that transferring the shims would be too tight. They make their pad width to take up that space. As far as bedding, yes, I would've preferred to get them already bedded, but there wasn't a listing for that. UPS screwed me and didn't deliver these in time for my last track day. The brakes took a dump and I had to nurse them for three sessions and didn't even go out for the forth. I have one last event for the summer, on Saturday at Laguna Seca, and just need to get these on and bedded. I just got home from work and I'm going out to finish buttoning things up. Then, go out tonight and bed them when traffic dies down. Also, this is a track-only car.
Any news on 2pcs rotor availability? Can it be a common hat with the PP/Mach1 and then a unique ring?
I know this question was asked several months ago, but I’ll share the information I received from Girodisc on February 19, 2025 via email:
“We’ve designed the rotors, but we haven’t produced them yet due to a lack of demand. However, there is a local car that we have identified that we could potentially use to confirm the design in the next week or so. If that’s the case, then we would proceed with the first manufacturing run.”
