I went to change my brake pads on my 2018 Mustang GT PP1 and noticed the right front caliper was wearing the pad uneven. There must be a piston that is sticking and causing more pressure to the other pistons. I didn't notice the issue until after the job was completed and I installed new rotors and brake pads. I was looking closer at the pads the following day and noticed when viewing the pads from the side that the wear was very uneven.
The car is still under warranty, but I swapped to stainless brake lines before swapping the brake pads and rotors. All fluid was flushed with Motul RBF 600 fluid. Now I wonder if Ford will honor the warranty about the defective caliper because the brakes were modified. Even if I put all the stock pads and rotors back on the car, it would be a PIA to swap out the stainless lines.
Has anyone had an issue with uneven brake pad wear with the 6 piston Brembos?
