AEROFORCE Gauge set up
Justin
I bought and installed the aeroforce dual gauge set up. and the instructions are so so so vague. When I press both buttons and go into setup which of the 4 do I pick?
Any other things I need to know would be great too. I have a 150psi fluid sensor to install (going for oil pressure) and I have a nitrous pressure sensor coming. can I wire both up off of the same 5v power supply that came with the oil pressure sensor?
384
Maui
Justin,
I'm pretty sure for 2011+ Mustangs you choose platform 4. I have the aeroforce dual gauge set up with the SOS dual gauge A-pillar pods. I like it a lot. I have 2 extra sensors, an oil pressure and oil temperature sensor hooked in to a glow shift oil filter sandwich adapter. I had a t-setup before going into the engine block but it eventually started to leak so I took it out. I'm not sure if you can hook multiple sensors up to the same 5 V regulator. Each of my sensors has their own 5V supply hooked into the fuse box through their own add a mini fuse. Just wanted to be safe. Oh BTW I ordered a JPC line lock that I'll probably PM you about installing. HAHa. At the end of the day we'll have many of the same mods...
Jeff
Jeff
Did you install nitrous? I would love to see your et and mph.
Justin
I have not installed it yet. waiting on all the parts to arrive. the holiday shipping rush is slowing every thing down.
