Am I running too hot?
I have a track pack with 4,400 miles, just back from the service where they fixed the drive mode selection unavailable.
Drove about 15 miles on the highway and then 10 miles on back roads, mostly in 2nd gear at 5k and over RPM, and some in 3 gear, at lower revs.
External temp was 80 deg. Isn't the read below way too hot? That's hotter than when I went to Palmer raceway.
That seems hot to me. I saw mid 220's on track running between 7-8000 rpm's.
I would keep an eye on it and check with Ford to see if those numbers are OK. I might (would) put the spurs to it to see where the temps go. Best to know before the warranty expires. It goes without saying that you kinda need to be discreet where this is done. At best, second gear gets you a fat fine. Third could put you in the pokey.
4,019
1,966
Unless you were hammering at 7500 to 8250 for those 25 miles then yes those temps are too high. limp mode kicks in at 244 CHT and 295 Oil temp on my GT so you aren't overheating but are close with CHT and on track it will come into play at high rpm.
