- 6,579
- 8,241
- Exp. Type
- W2W Racing
- Exp. Level
- 20+ Years
ArizonaBOSS said:@Fabman
I will continue updating the picture links so they work...might do some more tonight.
With respect to the 800/275, the car works really well and it's certainly not too stiff, but I am playing with ways to make the car rotate a bit more, as it was a little bit pushy at the limit.
My most recent "experiment" was swapping from a 22mm Strano rear bar to a 26mm OEM Boss LS rear bar. This seemed to work pretty well as far as rotation is concerned, but I need to get out on fresh tires to see how it really reacts. I may try a set of 650# springs in the front next season just to evaluate the difference.
I have my rear pivot point on the FAYS2 set 1 hole (roughly 1/2" ?) above stock location. I previously had it set about an inch lower than stock. This is all combined with any lowering from the suspension, as well. I didn't notice a big difference in changing the rear roll center height with either sway bar.
Height of roll center as measured from the ground is a pretty universal way to express it.
I'm very interested to see future developments. I'm on 500's and I'd like to go stiffer, but not sure how much stiffer.
Swapping springs at the track in these cars is a real pain so I prefer to do it at the shop, but that limits testing to one set per event. [font=verdana, arial, helvetica, sans-serif] [/font]
[font=verdana, arial, helvetica, sans-serif]With stock cars I'd often run several sets of front springs in a night dialing in for a specific track....but with the mustang, not so much. [/font]
I'm raising the watts one hole from 8" to 9" and stiffening the front shocks to manage body roll for this weekend.
I'd love to hear what setups others are running if they care to share.
