byronj said:Can I get some input on how they would be on a 9.5" rim? I currently have 275 all around but think 305s would be good
Flyboygsxr said:I run 305 square and do not have an oversteer problem...there are other ways you can tune the suspension to compensate for this...smaller rear sway bar, softer spring, adjustable dampers that you can soften in the rear, lower tire pressures, etc. I prefer monster turn in to horrible understeer. For me a drivers car will turn in for you and you control the oversteer with with brake and throttle application. It's so much more fun bringing the tail out than it is getting frustrated with the front end washing out and pushing. Understeer is safer but oversteer is so much more fun.
