DOT 4 brake fluids
How much is needed to do a complete flush of old fluid to new? I am looking at KNS, and not really sure which fluid to go with. I do plan on doing track days, however I am new to tracking the car. What's the best choice?
4,885
3,751
If you are careful you can do it with one liter, When switching to a new brake fluid, I used a liter and a half to make sure it was flushed out completely. ATE blue was ok but for the track, really really like Castrol SRF. After a long track weekend, on monday morning the Castrol felt like new, the ATE felt tired and needed a bleeding.
My technique: get a oil bottle that has a window on the side and is graduated so you can see how much fluid is in it (I use a mobile one bottle). drill a hole in the cap and insert your aquarium tubing. Take 4 ounces out of each corner for a full fluid change and to ounces out of each corner for a bleed.
Good answer, I wish I knew about this stuff sooner. I figured it would cost way more to use the SRF but in the end I use way less and save money.
Shaun12 - If you use a turkey baster or spray bottle nozzle to empty as much fluid out of the master as you can you will use less and make the job faster.
So if I get one bottle of the SRF stuff, it should be more then enough to flush out the enitre brake system and replace it with new fluid?
3,875
1,529
Get 2, and drain the master cylinder reservoir out with a turkey baster or if you have one a vacuum oil drain setup. This saves on the amount you have to push through to clear the lines. The Castrol SRF is the best brake fluid out there, it absorbs the least moisture of all the high performance fluids and has the highest "wet" boiling point. You can leave it in for 6 months or more depending on how hard you run it. It costs more up front but is worth the peace of mind.
PeteInCT
2,848
14
1.5 L for a full flush. Motul 600 is very good, Castrol SRF has the best specs. The sleeper that no one knows about if the Pagid RBF - very good specs and price is not as high as Castrol. It has the highest dry boiling temp. I sell it and also use it. EMail me for pricing if interested.
Dry Wet
ATE Super Blue 536 392
ATE Typ 200 536 392
Motul RBF 600 594 421
Pagid RBF 622 399
Castrol SRF 590 500
-Pete
