FS: 2012 - 2013 Boss 302S foglight opening mesh
Had a member here ask for this. Gloss black powder coated SS mesh cut to fit the foglight openings in the upper grille on a 2012 - 2013 Boss 302. This is the same mesh (shape, style and coating) that is used in the 302S racing grille. I only made one set, but if anyone wants a set, I can get some made. You get the 2 mesh inserts and enough wire to install them in you regular Boss 302 grille (once you cut out the openings and drill six small holes for each opening). I can sell them for $34 shipped if paying with paypal or $32 shipped if paying with a postal money order. Send me a PM or email if interested. Mike
And yes, my car needs a wash!
Re: FS: 2012 Boss 302S foglight opening mesh
I know the 2013 has removable fog light inserts, but I also see Ford makes a racing grill. Anyone have detailed pictures of 2013 racing grill? Not sure if the 13 uses the same mesh inserts in the racing grille?
USNjocson said:
Do the 2013 guys still have to drill in 12 small holes in the grille?
Yes, you will still have to drill 6 small holes for each side. That's how they attached the mesh to the racing grilles. There may be other ways, but the couple of grilles that I modified, you can hardly notice the wire that holds the mesh in.
mikebxb said:
great stuff!
i'm bookmarking this thread.
zipties?
do they rattle any?
No rattle as long as you install it correctly. Easy to install, you use fine wire, which I include, to install the mesh. This is the same as they do for the Ford Racing 302S grille.
