FS: bolt on jack plates for 2015+ Mustang
So I finally installed a set of my jack plates on a 2016 GT350R. The right side went actually quite easy. I used a 5/16 cobalt drill bit in my right angle Makita drill. The first hole I was able to drill thru the entire pinch weld. The second hole required me to sharpen the bit 3 times before I made it thru. The right side was a different story. I used that same cobalt drill but was only able to start the holes (make an indentation) with that bit, regardless of how sharp the bit was. I then switched to a 3/16 regular bit and was able to make a pilot hole. I then went up in bit size to 1/4, drilled out both holes, then switched to the 5/16 cobalt drill to finish it up. Left side took 15 minutes to install, right side about 1/2 hour. They sure fit nice though.
I installed Mike's plates. +1 vote here for quality fit.
For others looking to do the install, and who are as awful at body panels as I am, I found this video to be helpful in showing how to remove the rocker panel:
Also, if you are like me and manage to destroy a couple of push pins along the way, I found this this kit of replacement pins to be close enough (they are advertised as fitting 05-14 model years). The white "side" pins seem to be an exact match while the black "bottom" pins get the job done but remain a little loose for the final 1/8" inch. This would have bothered me more except a) I drove 1,500 miles on the car without having noticed that the factory left 5 of my driver side bottom pins only partially pressed and therefore wobbly, and b) I couldn't find any rocker panel push pins designed for an S550. So not perfect, but I felt better than nothing.
https://lmr.com/item/HDW-10176/Mustang-Rocker-Panel-Molding-Attaching-Hardware-05-09
If anyone has links to the correct "bottom" push pins, please share. I'm sure others will appreciate it.
