blacksheep-1
Epic Contributor
OK, so this has been an ongoing battle for many of us. Dealing with the Mickey Mouse fuel delivery system on these cars. I WAS PRETTY SURE I had it handled by stuffing the saddle with fuel cell foam, it worked fine until I went to Roebling Rd. In the relatively long left hander it started acting up. I dumped some fuel in it and sure enough, the problem stopped.
When I got home I pulled out the fuel pump/ sender stuff and sure enough the foam had migrated into the passenger side tank.
I pulled the transfer tube out and pre mounted the foam in the saddle " hoop" tie wrapping it down. Using a large tie wrap, I guided the tube back over the saddle and put it all back together. When I filled the tank, the gage slowly responded which tells me the saddle is now plugged with foam.
This is about the last time for this, I would change it to a cell, but I wanted to use a gauge and all the fuel cells only accommodate GM style gauges.
