HPDE tires
bnight has the magic formula we have all found --- square means quite a bit better life with a normal rotation procedure. With a Mustang those tiny tires up front just are not up to the dive under braking going into a tight turn.......can you say puuuuuuuushh!!
He has the Dark Horse, with 10.5" wheels up front and 305 Trofeos. So, while it is staggered, it is not like the GT performance pack staggered, and the front wheel and tire is nothing like the regular GT tire size. The rear on his Dark Horse is 11"
I plan to step up to 11" all the way around for track use in the future.
the rears on a Dark Horse handling packs are 11" but also the tire is 315 isn't it ? Otherwise that tire would have served very well as a rear tire was my point.
Yes, he was running 305 on the front and 315 on the rear, the tires Ford puts on the Dark Horse with handling package. 10.5" and 11" wheels.
The Trofeo RS 315/30R19 could fit up front with an 11" wheel. It has a very narrow tread width compared to that 315 size. Tread width is listed on Tire Rack as only 10.5"
Lots of other brands the 305 is a better choice, because the tread width is a lot wider than the Trofeo RS. For example, the Goodyear Supercar F1 3R is listed as 305/30 R 19, which should be narrower than a 315 Trofeo RS, right?
Nope.
It is 11.3" wide. So the other brand is .8 inches (almost an entire inch) wider tread in 305 than the Trofeo RS is in 315.
The front and rears are staggered right ? This is why I run square tires when my fronts start looking like yours I just move them to the back !
That’s the way to go for dure
Yipes! But the "cut" is on the inside of the tire. Damage to the fender well liner looks to be to the middle-ish/outside-ish. No damage to oil cooler!
yeah i see no ther rubbing issues i need check exactly
Nope.
Not sure what sizing actually means but the same size pilot sport 4s appeared to be exactly the same size as the trofeos sitting side by side
My buddy picked up the pirelli slick race car scuffs. We are going to see if they fit on my stick setup. Off a ferrari
