Excellent. Thank you for the update.
Any time you move the face of the wheel out from the hub you will increase leverage. A spacer will do just that. Tell me how it won’t? Is it a factor? depends. The fact you have to lengthen your studs should tell you that right off the bat The shear weight of the vehicle has moved outboard of the hub. Pretty basic geometry. Dealt with this in offroad vehicles. Big difference here is a sandwich spacer for increased strength with the lengthened studs. Some spacers bolt on to standard length studs and have new studs to bolt wheel on. Same result far less strongMore than a tire with the 26 offset? No way.
All we are doing is moving the wheel out to match the same position as the stock 26 offset, so we can use the 52 offset from the rear wheel ( so we can rotate).
I think the leverage would be exactly the same, since the wheel and tire are moved into the exact same position as the 26 offset with no hub.
It only increases leverage if you are moving the wheel and tire further outboard. In this case, the wheel and tire are in the exact same position.
No. The studs having to be lengthened does not change where the outside rim of the face of the wheel is. The lug nuts are further out on a 52 backspace wheel plus spacer - true. But the leverage is being applied from the tread back into the hub. Leverage is like a big lever. One end is the tread, and the other end is the hub. The tread is in the exact same spot relative to the car as the 26 backspace wheel would be without a spacer, so the leverage force acting on the hub is the same when you compare a 26 backspace 11" front wheel and a 52 backspace rear wheel installed on the front with a spacer to put the tread in the same location.Is it a factor? depends. The fact you have to lengthen your studs should tell you that right off the bat The shear weight of the vehicle has moved outboard of the hub. Pretty basic geometry. Dealt with this in offroad vehicles. Big difference here is a sandwich spacer for increased strength with the lengthened studs. Some spacers bolt on to standard length studs and have new studs to bolt wheel on. Same result far less strong
After they've had a good amount of time to cool though, right? I know it often goes without saying around these parts, but if a cold torque rating is applied to a hot stud after a lapping session the nut may feel looser than normal for different reasons...I torque after every session amazed how they loosen up
| brand | model | 295 | 305 | price | UTQG |
| Bridgestone | Potenza RE-71RS | 30 sq | 2000 | 200 | |
| Bridgestone | Potenza RE-71RZ | 30 sq | 2140 | 200 | |
| Contenintal | ExtremeContact Force | 30 sq | 1700 | 200 | |
| Falken | Azenis RT660+ | 35 sq | 30 sq | 1800 | 200 |
| Goodyear | Eagle F1 Supercar 3 | 30 | 30 | 2100 | 220 |
| Michelin | Pilot Sport Cup 2 | 30 | 30 | 2300 | 240 |
| Nankang | Sportnex CR-S | 30 | 30 | 1700 | 200 |
| Vitour | Tempesta P1 P-01R | 30 | 30 | 1900 | 200 |
| Goodyear | Eagle F1 Supercar 3R | 30 sq | 1800 | 100 | |
| Nitto | NT01 | 30 sq | 2340 | 100 | |
| Pirelli | P Zero Trofeo R | 30 | 30 | 2500 | 60 |
| Pirelli | Trofeo Track | 30 | 2485 | 40 | |
| Toyo | Proxy R | 30sq | 30 | 1400 | 40 |
Always right before i go out. Not when i come in so usually that’s at least an hour. Or two. Is there a hot and cold torque rating? I know the coated studs at op use less torque all aroundAfter they've had a good amount of time to cool though, right? I know it often goes without saying around these parts, but if a cold torque rating is applied to a hot stud after a lapping session the nut may feel looser than normal for different reasons...
The general guideline is not to touch them at all when hot, as trying to torque them down to the cold number can stretch the stud, deform the threads, or outright snap the stud due to them now being over-torqued when they return to their cold state. An hour should be fine. Just wanted to double check, since a wheel unexpectedly coming off can be a "significant emotional event" hah.Is there a hot and cold torque rating?
