Interesting trick with your Instrument cluster
That is interesting. It's reading the same data as the Aeroforce gauge I installed. Here's how it works:
"I think you can view all of this without an added gauge. I haven't tried it on my Boss yet but if you hold down Setup and Reset while starting the car you can view all of the feed back from the car's sensors. Just try hold down the 2 right buttons. I think its setup/reset"
My 04 Cobra did the same thing. After you start the car and set it to what you want to see you can leave it there and watch it while you run on the track.
Here is the full list of parameters.
[pdf]http://forums.themustangsource.com/attachments/f813/116043d1343606064-laguna-gauge-pod-installation-ipc-diagnotic-mode-chart.pdf[/pdf]
