Is this the right ABS module to upgrade to?
I have a 2005, 18*11 on slicks. Caliper/rotor/pads upgraded, road race only. I was told to upgrade the abs module. I think this is the part.
FORD RACING M-2353-A ABS MODULE FR500S​
Can anyone confirm, it should be plug and play from my understanding.
I believe I should also looking into making sure the traction control is disabled so I dont forget to turn it off one day.
Thanks
Thanks
That module was used on 2012 Boss 302S and R models based on Coyote engine. I don't know if pre 2011 coyote harnesses and ABS module are compatible with a 2005 harness and ABS module. Do a search on this site. I figured out how to turn off Traction control like the module by disconnecting Can bus high signal to ABS module and posted DIY.
