If you maintain 14" front rotors are there any issues with increasing the rear rotors to 13" or 14"? I've been told by a couple of people that it's not a good idea to install 14" rear rotors with 14" front rotors. Why? Regardless if there is a possible imbalance in the system wouldn't ABS compensate for that? Anyway I'm looking at the three kits below. I'm leaning towards the Steeda 13" kit but I'm not looking forward to installing it. I'll probably have someone install the kit for me. Thoughts?
BTW the reason I'm considering this is I'm going to upgrade my front rotors and calipers to increase heat dissipation and want to do something similar for the rear. Plus the stock rotors look so small.
Steeda 13" Rear Rotors: advantage is replacement rotors are inexpensive.
http://www.cjponyparts.com/steeda-rear-disc-brake-upgrade-kit-13-inch-2005-2013/p/DBR22/
Baer 14" Rear Rotors: advantage is installation is easier. I've been told you can order slotted only rotors.
http://www.cjponyparts.com/baer-rear-brake-rotor-upgrade-kit-eradispeed-plus-two-14-inch-2005-2013/p/BR37/
Ford 14" Rear Rotors: advantage Ford parts and replacement rotors are the most affordable.
http://rehagenracingproducts.com/Shelby-GT500-350mm-Brembo-Rear-Brake-Upgrade-2005-2014-MUSTANG-RR-2300-TRA.htm
