Do LCA Relocation Brackets increase the potential of understeer or worsening what is already there??
2012Boss302 said:Do LCA Relocation Brackets increase the potential of understeer or worsening what is already there??
Jimmy Pribble said:![]()
Just had a tire test day with Capaldi Racing at COTA. They brought three cars (including a '14 test mule) and two Ford Racing engineers. Two of the three cars were equipped with relo brackets, but ALL of them had the LCAs at stock location. I noticed the same at the COTA WC race earlier in the year (photo). When I asked about it, Craig Capaldi said, "Why would we want to give-up grip?" He didn't elaborate and I didn't ask further. I will reach-out to them today and find out if that is simply how they like to set-up their cars or if there is another absolute reason why they aren't using the adjustments.
Champale said:Well that blows my theory out of the water, Jimmy!
Very interesting. I wonder if they are tinkering with geometry via something else? Are they running Watts links? Adjustable length LCAs? UCAs?
Thank you for that info.
John
So IMSA is going to allow them to run a Watts link for 2014? Do you know which one they are using? Regarding the UCA previously they were only allowed to use the Multimatic modified stock unit that was stupid expensive. Regarding the location of the LCA's in the relocation brackets will the size of the rear sway bar affect this decision?Jimmy Pribble said:Well, let's just see what answers I can get out of them. The '14 test mule has a Watts Link, because this will be the first year they are allowed. The other two cars have typical setup, as far as I can tell. They all use the Ford Racing non-adjustable LCA. I do not know about the UCA. Same applies to the two different cars I saw earlier in the year.
NFSBOSS said:So IMSA is going to allow them to run a Watts link for 2014? Do you know which one they are using? Regarding the UCA previously they were only allowed to use the Multimatic modified stock unit that was stupid expensive. Regarding the location of the LCA's in the relocation brackets will the size of the rear sway bar affect this decision?
