lower front grill and LS brake duct inserts suggestion
2,119
953
Bay Area
Hey guys - so my car got hit by a retread on the freeway. Since the car is going to insurance I am going to put LS brake duct insert installed and am looking for a new lower grill. What are some good suggestions and can I get P/Ns. I did a quick search put haven’t had much time and need to get the car over to the body shop soon.
Thanks in advance.
I'm not sure there are many lower grille options. Maybe look at the GT500 if that's different. Are you going to install the brake duct kit later? If so the 2012 kit came with new openings so maybe the 2013 does too? If so I'd stick with the stock ones and then use the ones with the kit when you order it so you have both.
IIRC Roush makes a lower grill insert that is wide open which should help with cooling as well.
http://www.roushperformance.com/parts/2013-2014-Ford-Mustang-ROUSH-High-Flow-Lower-Fascia-Opening.html
