MM castor camber plate install question
713
69
I bought a set of used plates. They did not come with the spacers. I read the instructions and they say they are not needed for our cars 2011+.
I just want to make sure that I won't need them before I bring the car in for installation. Or do I need to order them from Maximum Motorsports.
Any help would be great, Thanks
I did not use the spacers.
It depends on what dampers you are using. The stock Boss dampers are a 2011+ style so you don't need them. The FRPP M-1800-C dampers are 2005-2010 style and that's what the spacers are for. If you look at the instructions there is a graphic that shows the difference between the two styles. I'm assuming you're talking about the MM c/c plates for 2011+ cars part # MM5CC-6.
I thought we discussed this and determined neither of us are using the spacers?
713
69
I read the the inductions & that's what I got. I just wanted to make sure before I brought it in to get done. Thanks guys!
Senderofan
The instructions will show you the difference between the 2005-2010 damper versus the 2011+. Basically the 2011+ have the threaded area that measures 1.5 inches. The older, 2005-2010 style, has a narrowed area that has threads that measures 3.0 inches. The newer styled dampers do not require spacers.
My apologies if this was communicated in pm's etc. I have studied this recently as I'm gearing up for the install....once our snow melts and the temps stay above freezing ;D.
Wayne
713
69
Wayne
Got it, thanks for the reply!
