I am experiencing pulsating braking during hard braking on track at my last two events.
This is a first for my car. Maybe 10 track weekends with these brakes with no issues before now. Need some experienced input.
I want to have this solved before my next event in two weeks, but I prefer not to raise my car and pull back the calipers over and over.
I don't see evidence of non-uniform pad distribution, but maybe that is not scientific anyway.
I tried sanding rotors in the past but I did not observe any material getting removed from the rotor.
Is there any good reason that I cannot simply have the rotors turned to remove pad buildup and start fresh? They have worn only 1/2mm from new thickness.
Thanks.
- GT350 brakes
- OEM rotors and pads (Ferodo) near half life
- Ti shims added before first of the two events
- I swapped out the wheels and tried some moderately hard braking on the highway from 80mph. The symptom remains.
- I checked runout on the outside rotor faces and they were true.
- I can measure runout of all the wheels, but I think they are true and not the problem.
- I plan to take out the shims and swap over to my street pads, which are like new.
Thanks.
