S197 Drivers Side Door
Does anyone know what the difference is between the drivers side door P/N
AR3Z-6320125-A and AR3Z-6320125-B for a 2013 mustang? I can pick up a brand new "A" version for a lot less than the "B" but am unsure of what the difference is.
Thanks in advance
TymeSlayer
3,787
2,741
Brighton, Colorado
The "B" door is just a replacement door for the discontinued "A" door but couldn't tell you what changes were made to it. I'm sure for form, fit and function it should work. Double check with the dealer before you order.
I asked a dealer today and got the deer in the headlight look.
I am not sure how Ford performs configuration management but something changed to drive a P/N roll; maybe a vendor change and the "B" door is still built to the original OEM specs?? Who knows? The door components all retain the "A" configuration so I have to assume the components will transfer over without issue.
Their part numbers change a lot. If it shows it fits your car you should be fine. Or call someone Like Autonation White Bear Lake and ask them.
This. It's a common practice for the current Ford parts numbering system to change the letter suffix for updates.
From Tasca:
