New Ford Racing M-6642-MBA air-to-oil oil cooler kit. $875 $675 plus actual includes UPS Ground shipping. Payment by Paypal. Local pick-up OK (Littleton, CO)
I bought it last winter. I did not install the FRPP kit but instead built my own oil cooler set-up using a larger size Setrab cooler to compensate for the higher altitude in Colorado.
Box was opened to inspect the contents. All individual parts are in their original packaging as shipped by Ford Racing.
Drop me a PM for questions or if you want to buy the kit.
Ford Racing Part Description:
MSRP: $1,250
Fits 2012-2013 Mustang Boss 302. Recommended for track use. Capable of removing between 27,000 – 39,000 btu/hr of heat.
Kit includes: Black anodized billet aluminum oil filter adapter. Setrab oil cooler, fully brazed construction with black epoxy finish (15.94” wide by 4.53” tall). Pre-assembled, light weight, AN-10 smooth bore hose with 5-ply composite construction. Hose is rated to 400-degrees F with a burst pressure over 1000 psi. Black powder coated cooler bracket. Installation kit includes AN fittings, cooler isolators and bolts/washers/nuts (and installation instructions).
Box size: 12” wide x 18’ long x 9” high
Box weight: 8.5 lbs.
MSRP: $1,250
