SOLD - UPDATED FS: New FRPP Boss 302 Oil Cooler M-6642-MBA - $675 Shipped CONUS
New Ford Racing M-6642-MBA air-to-oil oil cooler kit. $875 $675 plus actual includes UPS Ground shipping. Payment by Paypal. Local pick-up OK (Littleton, CO)
I bought it last winter. I did not install the FRPP kit but instead built my own oil cooler set-up using a larger size Setrab cooler to compensate for the higher altitude in Colorado.
Box was opened to inspect the contents. All individual parts are in their original packaging as shipped by Ford Racing.
Drop me a PM for questions or if you want to buy the kit.
Ford Racing Part Description:
MSRP: $1,250
Fits 2012-2013 Mustang Boss 302. Recommended for track use. Capable of removing between 27,000 – 39,000 btu/hr of heat.
Kit includes: Black anodized billet aluminum oil filter adapter. Setrab oil cooler, fully brazed construction with black epoxy finish (15.94” wide by 4.53” tall). Pre-assembled, light weight, AN-10 smooth bore hose with 5-ply composite construction. Hose is rated to 400-degrees F with a burst pressure over 1000 psi. Black powder coated cooler bracket. Installation kit includes AN fittings, cooler isolators and bolts/washers/nuts (and installation instructions).
Box size: 12” wide x 18’ long x 9” high
Box weight: 8.5 lbs.
Re: FS: New FRPP Boss 302 Oil Cooler M-6642-MBA
ArizonaGT said:
Wow killer price there.
Thanks. I'm just trying to recover the cost of parts for the DIY oil cooler.
I think one of Santa's elves got a good deal on the FRPP kit last November at a Late Model Restoration pre-Christmas sale...something I saw on the CC bill for $1,012 ;)
Re: UPDATED FS: New FRPP Boss 302 Oil Cooler M-6642-MBA - $675 Shipped CONUS
UPDATED PRICE: $675 – Includes UPS Shipping; Continental USA and PayPal fees
If you were to build your own, the individual components (or *similar) to make the kit are:
Setrab 50-915-7612 oil cooler, Series 9, 15 row ($195 – LPI Racing)
Setrab M22 to AN-10 adapter, black, M22AN10, 2 each ($22 – LPI Racing)
Setrab oil cooler rubber isolation pads ($10 – estimate)
Canton oil cooler sandwich plate adapter, 22-549 ($70 – Summit Racing)
*Aeroquip AN-10 to 1/2" NPT adapter, black, FBM5009, 2 each ($10 – Summit Racing)
*Aeroquip AN-10 Startlite Racing Hose, 10 feet, FCU1010 ($87 – Summit Racing)
*Aeroquip AN-10 straight hose end, black, FMB4414, 2 each ($28 – Summit Racing)
*Aeroquip AN-10 45 degree hose end, black, FMB4424, 2 each ($52 – Summit Racing)
FRPP powder coated oil cooler mounting bracket (custom one-off - $150 - estimate)
Nuts, Bolts & tie-wraps ($10 – estimate)
Labor to install hose ends ($25 – estimate)
I want it.
I sent you a message
Best regards,
Patrick
