supporting or other neccesary hardware.
Discussion in 'Vorshlag Motorsports' started by TCactus04, Nov 26, 2018.
  1. TCactus04
    TCactus04 TMO Beginner
    Jul 14, 2018
    Atlanta, GA
    Hello TMO and Vorshlag,
    I have already had a great experience with Vorshlag. I emailed about spring rate suggestions and got an email back from Terry Fair in a very short time. Then a call from Jason, we settled on the GTS rate for the MCS package. Then he sold me on his plates over MM. I decided to post here instead of emailing or calling. I figure maybe the thread could help others with the same question, which may have already been asked. All opinions and recommendations are welcome, please.
    I got the 1wnr MCS coilovers, GTS spring rate (600 front / 750 rear), Vorshlag CC plates, rear shock mounts, whiteline swaybar kit with adjustable endlinks, and steeda subframe aligment and support kit.
    On to the question....will I need anything else? I mean "need" in the most direct form, such as the "one time use" shock and strut hardware (MM recommends it with their kit), or extended ball joint or bumpsteer?
    My hope is to get to a track day...one day to answer the intended use question. However I do want to setup a very properly driving car.
    More to the history future part, it is a non-pp car, strut tower suggestions? Brakes will be next on the major expense list.
    Thank you everyone, and if this is the wrong place to ask, please move the thread.
    VoodooBoss likes this.
  2. VoodooBoss
    VoodooBoss Rick Moderator
    20,375
    2,762
    Nov 30, 2010
    Welcome to TMO. The CC plates should come with new hardware. The lower strut bolts are one use bolts so plan on replacing them. From your spring rates I'm guessing you have a S550 Mustang? Your plan for brakes is a good choice and Vorshlag can help you out there. @Fair
    TCactus04 likes this.
  3. ArizonaBOSS
    ArizonaBOSS Because racecar. Moderator
    8,166
    1,758
    Dec 6, 2010
    Brake cooling and fluid flush, if not already done!
  4. TCactus04
    Jul 14, 2018
    Atlanta, GA
    Yes it is an s550, 2015. Sorry that should've been more clear.
    Almost wish I had gotten brakes first honestly. This stuff was all a birthday present/bonus from work, so wanted to spend as much as I could.
    So I'll definitely get the lower strut bolts and nuts. I'm just on the fence really about the bumpsteer and roll center. It is easy enough to wait and see, but I'd rather be extremely happy day 1. Not, oh I wish had ordered other stuff too. I just don't see that recommended or mentioned anywhere except the steeda product page.
    ArizonaBOSS likes this.
Share This Page
