I did the spherical/poly on my car years ago, but the spherical is on the differential side and poly on the body side. It has worked well for me.
I have not been under my car in awhile, but from what I remember you can't get a torque wrench on the upper end of the arm with it on the car. I had to take the bracket off the car to remove the upper link from the bracket.I can manage setting the car to ride height. My question was specific to why the ford piece comes assembled with no apparent instructions to retorque in the service manual. Is there something special about that particular bushing?
Easiest way to get to it is with a crowfoot at 90 degrees offset so it doesn't change the torque value on the wrench (or re-adjust the torque setting from the longer lever-arm), but I've had the BMR mount for so long I've forgotten if the OEM one was more difficult. The manual does call for the stock bushing to be tightened at ride-height. Some BMR versions call for the same, while others in their catalog are torqued on the bench. If you can get at it, I'd try to follow the instructions from the manufacturer of the part.you can't get a torque wrench on the upper end of the arm with it on the car
I think end of MY 11 and all of 12 got fixed for that rack issue.. but that's just what i read. I'm to scared so i leave my front control arms stock and just deal with the lack of precision. When i start adding downforce and huge spring rates, it will be time for hard bushings!I have a 2011 GT that is set up for street and track, daily commuter. Following advice here on TMO, I use an upgraded PHB and LCA (I currently have Maximum Motorsports but lots of brands will work) and an OEM upper 3rd link and this setup works very well. It's maybe a little counter-intuitive but the key in the rear is to use relatively soft spring/bar rates combinedf with upgraded dampers with plenty of rebound control. Use a small rear bar (~18 mm) or none at all. This gives a great ride on the street and awesome rear axle control. On track the back end stays behind you, you can absolutely eat up curbing, and you can put power down amazingly well off the apex. See @blacksheep-1's videos of the Phoenix S197 to watch a pro using this type of basic setup, super fun to watch. It feels a little weird at first and you have to keep weight on the nose getting down to the apex but it's easy to drive and really fast.
In the front, be aware that in our 2011's an aftermarket control arm bushing will likely cause a bad feedback loop in the electric steering rack that causes severe steering wheel shudder. Either leave that bushing stock or swap in a Boss rack, or maybe a later year '13 or '14 rack. Your mod money is much better spent replacing the upper spring perches with good camber plates from Vorshlag which do all sorts of awesome things and are perfectly streetable IMO.
Good luck and welcome.
I believe you are off a year. All 2011 and part of 2012 were affected be the epas problem.I think end of MY 11 and all of 12 got fixed for that rack issue.. but that's just what i read. I'm to scared so i leave my front control arms stock and just deal with the lack of precision. When i start adding downforce and huge spring rates, it will be time for hard bushings!
That is correct. We uncovered all of that in our 2011, many other 2011 cars that belonged to customers and a single early 2012 customer car.I believe you are off a year. All 2011 and part of 2012 were affected be the epas problem.
Could be since that's what i meant. lol.I believe you are off a year. All 2011 and part of 2012 were affected be the epas problem.
