vinyl sticker removal
Sesshomurai
Hi,
I bought some custom die cut vinyl stickers for my racing numbers. These are the pro automotive kind and resemble the OEM stickers in quality and look. So if I need to remove my stickers someday, how is it done? Some kind of solution?
Justin
I haven't removed the factory boss decals but others I have used a heat gun then go back with denatured alcohol and a microfiber towel to remove the glue residue. WD-40 will also take of glue residue
like mentioned, heat gun would help greatly. I've also used Goo Gone (bought from walmart) to successfully remove any left over adhesive residue. it is recommended to, at least, spray a quick detailer or spray wax once the vinyl is off.
I used that **** like Justin uses Zaino. You need to make sure and get it all off though, or it will leave white gunk on rubber.
