This came out of necessity, but it has turned out to work quite well. Several things lead me down this road.
Back when my car was NA, my stock grill with the foglights cut out still resulted in 250F coolant temps at Sebring and AMP on 90-100F days.
My stock grill was damaged.
I put a blower on and wanted more airflow to keep the car from overheating.
I came up with this:
I later perfected it by stuffing some 1/2" foam from mcmaster (PN 85175K89) into the top and sides. Back at sebring I pulled the entire grill as the manual suggests and did not like how the hood fluttered at 120mph+. This seems to be a better solution, as it keeps too much air from going in the grill. The foam also blocks off the hood latch area but still allows you to use it, I was careful to make sure it did not interfere with latching operation.
The GT grill surrfound is around $85 wholesale from ford and comes flat black, the PN is AR3Z-8419-AA. I stole the surround from another car and broke some of the clips in the process, but a new one should be more flexible. I made a small bracket to put the pony back in the grill.
When I damaged the stock grill I was just going to do a 13 front end conversion for the different look and improved airflow between the grill and hood, but this setup is turning out to be very functional, though kind of utilitarian looking.
