A realistic option?: electronically-adjustable shocks
Sounds nice, but wouldn't want to be the first to try it out.
I'd like to see Multimatic do something similar with DSSV, although it would take away from the relative simplicity of the mechanical spool valve.
That system is supposed to work well and Cortex is supposed to test a set. I have not heard if they received them.
DSSV dampers for the masses would be cool.
5,287
4,288
Staying tuned-in then. If Cortex made a set that would make feel happier about it. Can you imagine plugging in your laptop to make a mess of your suspension settings!!o_O
8,733
2,735
I have forwarded this to a buddy of mine that works at RideTech so maybe he can answer in more detail. I believe in our previous conversation regarding this tech, he mentioned it was "not cheap".
Hi guys! I work for Ridetech and we have been working on this for awhile. We work directly with DCS and Tracktive. We are learning as much as we can from each other and making this new "Public" suspension technology available. When it comes to the electronic valving and even the magnetic fluid in the 350/350R dampers we are your source.
