- Thread starter
- #641
captdistraction
GrumpyRacer
I will give that a shot! I wasn't sure how I could pull it off without damaging it, but I might just pull the unit out with the valve attached (as its easiest to remove there), open the valve with a jumper wire, fill it, close it and once primed I'll reset the empty unit to the correct air pressure range
Made some progress, the motor is basically assembled just need to finish some wiring work and lift it in:
![Install Steps.JPG Install Steps.JPG](https://trackmustangsonline.com/data/attachments/3/3518-33593d590abd89faa6928479e0be27b8.jpg)
