Kenny Brown AGS 4.5: Have I Been Living Under A rock Or Is This Brand New?
5,276
4,277
Thats it in a nutshell! Especially in the case of beating the next guy off the corner. Pretty much the strongest area for our stick axle mustangs.
344
364
Let me say right up front that I am no suspension guru but I have always been taught that three basic things are true:
1. Unless you have aero, try to use as soft a spring rate as possible to maximize mechanical grip, provided body roll is reasonable and suspension geometry is maintained;
2. Increased weight transfer = reduced lateral grip, since the inside tire loses more grip than the outside gains; and
3. Assuming similar tires, the only things affecting total weight transfer (and thus total grip) are weight of the car, width of the car, center of gravity, and speed. Period. Using things like spring rates, rollbar sizing, and adjusting roll centers, you can tune which end of the car is carrying what percentage of the total weight transfer (understeer vs. oversteer), and whether weight transfer manifests as body roll versus jacking forces - but you cannot reduce the total weight transfer.
If these things are true, I am having trouble seeing how dramatically dropping the roll center on one end will dramatically increase total overall grip? I can see how it would reduce the percentage weight transfer on that end, similar to removing a roll bar or softening springs. And I can see adjusting front versus rear roll centers as one technique to achieve front/rear handling balance. But as @Fabman suggests, I am having trouble seeing how a super low roll center combined with super stiff springs to control roll is a net gain, and it seems as if it could be a net loss if #1 is true? (In fact, isn't this one reason we work to raise the roll center in the front with things like extended ball joints, so we don't need to run so much front spring rate?)
I know KB really knows their stuff and it is likely I am missing something (many things?) but for now put me in the Watch and Learn camp I guess.
49
43
Nashville, TN
I look at it like;
Let the car rotate around the roll center without reducing load on the inside tire. This is why I don't typically run a rear sway bar. (never say never though)
Its job is to add load to the outside tire by taking it from the inside tire and adding that spring rate in with the total roll couple. Seems counter productive to me.
With a high roll center you share the load more equally but load transfer from body roll is expressed at the contact patch rather than around the roll center.
Too high and the car just skates. Others like big rear springs to keep a balanced chassis. But again, too much and it skates and as a nice bonus you sacrifice forward bite.
I like low roll centers and soft springs. I'll deal with the body roll and understeer as long as I continue to beat the next guy off the corner.
However, I continue to test and try different approaches and combinations in the quest for lower lap times....who knows what I might find.
And that's the fun of it....right?
That's why we like tweaking! Interestingly, one of the first things Kenny Brown always said was "throw away the rear sway bar and lower the rear roll center." One would think it would push like a pig, but if it works, it works.
A higher rear roll center actually loads the tires *less* evenly because of the jacking effect (assuming the CoG is higher than the roll center, that is). A higher rear roll center has the same effect as a stiffer rear sway bar: more load on the outside tire relative to the inside tire.
If you look at the Roush Boss 302R cars from the Grand-Am days, you'll see them move all over the rear axle. Their bodies "sat" a lot lower at the rear than even everyone else's Mustangs...yet they still passed ride height tech (hmmmm...).
Anyway, two takeaways from what I saw of their cars: Billy Johnson drove those cars on the outside rear. The inside front off the ground...a lot. Even on level turns. I suspect they ran the rear roll center much lower, *and* they ran the rear of the car very soft. It moved around a lot like a contemporary NASCAR (which, given their area of chassis engineering expertise, makes sense). The cars were fast, but they also looked like your average Joe would complain about massive push. Billy would dive the car down in the corners, mash the gas, and drive it out on the outside rear tire. That probably minimized the understeer.
(Merely my observations trackside and in photos.)
Agreed on all counts...at least in theory. What's weird: accounts of how this setup works on real cars leads me to believe there's more going on than we may realize. I'm growing more convinced that the extremely low roll center benefits a live axle car more than an IRS because live axles seem to be more sensitive to the jacking effect with above-ground roll centers. Maybe the corner exit bite from minimizing jacking the inside rear wheel outweighs the loss forward bite from stiff(er) rear springs. Going back to theory, however, if both rear wheels are more evenly loaded (from the low roll center), then the rear diff can be "looser," which also reduces understeer.
All food for thought!
Wes,
the beauty of the K-link is not just the vertically adjustable rear roll center, to better tune to the front roll center, but also the fact that because of the linkage design, the chassis is free to roll around the rear roll center without upsetting the weight on the inner and outer rear tires. I can put my race-jack at the A pillar on the jacking rail, jack the left front tire 5" off the ground, and while the left fender may be raised almost 5", the left rear tire is flat on the ground. When running hard, rear tire temps run fairly even across the rear, and at times maybe even slightly higher temps on the inside edge of the rear tires.
So yes, there's more going on than we realize. I went to 650# spring rate in rear when I started running Pirelli slicks and Trofeo's. I ran with 450# in rear when running with R888R Toyos and it worked fine.
Keep an eye out for the BMR A-arms. They should be on your track day inspection list.
Yes, I have been. The car goes up on my lift after each event, and to do a full inspection, including the welds on the lower arms. I may opt to install the BMR upgraded arm, but I'm also considering fabricating full gussets and welding them in place this coming off season. Jury is out right now. Thanks for the heads up!
602
539
Drivers Mustang Club. Dec-18-22 at Button Willow Raceway Park. With a personal best time of 1:57.3 got me a 3rd place finish. Running Kenny Brown K-Link, Upper control arm module, lower control arms and anti-squat brackets.
Drivers Mustang Club. Jan-28-23 at Button Willow Raceway Park. With a time of 1:57.4 got me a 3rd place finish. I was running a Panhard bar in the stock location, Multimatic upper control arm, Boss302S lower control arms and anti-squat brackets. With this setup I had a new Personal best of 1:56.7 in the Bonus round at the end of the day.
Weather being close to what it was in the Dec event the only things I changed was the Kenny Brown stuff and the rear spring rate of 250lbs. I'm not real sure what to make of this Myself but laps times don't lie.
8,731
I think there is a lot to be said for adapting driving styles to maximize what a car can do well. There are a lot of expectations that a car will (or must) do *everything* well; once a driver can get the car as good as it can get, they have to make sure their driving style will emphasize these advantages. Similar comment for driving different types of cars; you have to adapt to the machinery.
6,574
8,238
"The car is a machine, it only knows what you tell it".
6,574
8,238
Drivers Mustang Club. Jan-28-22 at Button Willow Raceway Park. With a time of 1:57.4 got me a 3rd place finish. I was running a Panhard bar in the stock location, Multimatic upper control arm, Boss302S lower control arms and anti-squat brackets. With this setup I had a new Personal best of 1:26.7 in the Bonus round at the end of the day.
What did the Butt Dyno tell you?
49
43
Nashville, TN
I'm a little confused by your account. You list three times, but only two setups. Also, you list the later date first, then an earlier date. Did you mean to say Jan 28, 2023?
602
539
I did mean 1-28-23, I changed it thx. As for the times. only the first 3 session count for the points, the 1:56.7 I got was after that on a bonus run
602
539
The very old butt dyno told me that the K-link was smoother but not faster. in Dec I was consistently 1:58's all day with a couple on 1:57's thrown in. Last Saturday was consistently 1:57's all day with a 1:56 thrown in but was not as smooth. The track was cold and lose for all the S197 on the 28th, I was no exception and still managed a good time.
6,574
8,238
How did they "Feel" to you....and how was the balance of each?
49
43
Nashville, TN
Noted. You also state "With this setup I had a new Personal best of 1:26.7 in the Bonus round at the end of the day." Do you mean 1:56.7, not 1:26.7?
602
539
K-link balance was neutral mostly with 600lbs all four corners. Power was even all the way through the turn, entry, middle and exit. Stock setup had a tad more front grip but at the same time there where places I could put the power down sooner stock. Then I tuned the front grip right out off it and had more push.
344
364
@Tri-bar very interesting results and thanks for posting.
Just trying to follow along and learn the big themes. It seems like a pretty consistently fast setup for the S197 is to have a little front bias/understeer in steady state cornering combined with a good amount of anti-squat geometry in the rear. It seems like the combination of the rear tire friction circle not being maxed out with cornering loads, together with anti-squat to transfer weight as quickly as possible on power, really helps put power down as quickly as possible off the apex which is kind of our secret weapon. It also seems like it doesn't make a lot of difference in lap time whether one achieves the slight front cornering bias/push by way of a really low rear roll center (K-link) combined with high spring rate, or a higher rear roll center (stock PHB) combined with a lower spring rate and/or small or no rear bar. Too much rear bias in cornering makes it hard to put power down without blowing off the rear tires. Watts links are nice for easy adjustability of rear roll center. Am I understanding this sort of correctly?
602
539
Seems to be that in a nut shell. The K-link worked well with the front grip kit, it works with out the front grip kit. The car was flat and balanced well, was easy to drive. The stock setup front and rear with softer rear springs was faster but had to drive it a bit more. I myself, I like the car to move around a bit, squat, dive, roll. It lets me know where the weight is going so I can adjust. But that's just me.
