L&M Cams - Need Advice
165
320
Chicagoland
Reviving an old thread here.... Did you ever dyno the car after installing all the above? Looking at the L&M intake only cams for my 2012 GT but not sure if it's worth all the effort for a 15whp gain.
1,289
1,113
Philly Metro Area
It's not necessarily just an issue of gain in peak HP, but also where. On my 2014 I experienced a peak HP gain of about 40hp with a combination of the L&M intake cams, Boss 302 exhaust cams, 2018 manifold, and shorty headers.
But the most significant change was extending the gains out to 7600 rpm. Prior to those changes, HP would nose dive after 6400 rpm.
6,436
8,347
No it wasn't directed at you specifically, but unless the engine is fairly new, it would be good to install valve springs since you are right there. This is one of the things that keeps me up at night with superbeater.. 185K on the valve springs.
I'm not sure if this is directed at me, but I have the Boss 302S valve springs. However, if I had to do it over I'd consider the Livernois valve springs that @docs302 will be using
They're in between the Boss and PAC springs
Adam at Revolution Auto recommended the Boss302S springs. I mentioned going with higher rate springs like PAC and he felt that the extra energy needed to open those units was not worth it or required. I know others here on TMO have had success with the PAC springs and since I was planning to rev to 8K I felt a higher rate would ensure I don't get valve float. I wasn't a fan of the high price for the PAC springs and found the Livernois springs with a rate (and price) in between the 302S and PAC which I felt was perfect. Can't tell you yet how they work but they fit like stock and I feel more comfortable with that decision.
