Lund Racing Tunes a GT350
They didn't waste any time on this. I thought the baseline number would have been a bit higher than 442. We'll have to see what @Shaun@AED can do with one.
https://www.facebook.com/LundRacing/?fref=ts
8,733
2,735
That's a Mustang Dyno, so it's going to read low compared to the numbers you typically see from a Dynojet. That is very likely north of 500hp on E85 on a Dynojet.
The bump in torque with E85 is also quite significant.
And yes, I'm assuming you'll need a tune for E85 (since they were tuning it). Beware, you'll use about 1.8-2x as much fuel if you're on E85.
Generally I would agree, but with the High Compression Ratio of the VooDoo engine I would expect that number to be a little bit lower (the amount of fuel you use on E85 vs. say 93). Bruce (one of the resident engine guru's on S197) had posted a study a few years back that showed that the closer you got to 13:1 or 13.5:1 the smaller the fuel economy gap was on an engine. They had found that at that compression, the engine had the same fuel economy as the same engine when running 93.
