Post your tow strap/hook setup
Bugs
Jim. Avocation: Avoiding Blunt-Force Trauma.
35
68
Eagle ID
I did not see this rear hook on the ZL1 site. I guess that mounts to the rear bumper beam? I want one.
Hi Stan, The ZL1 website doesn't seem to have a picture of the rear tow hook, but you can buy it by selecting from their pull-down menu.
Here's a photo of the rear tow hook attached to my rear bumper bar:
8,496
8,495
You gotta love the Mach 1 set -up , following the lead from Porsche or other makes where you just screw it right into a receptacle made at the factory. I still have the one from my Silver Mach 1 and it takes maybe 5 minutes to put on , max ( more like 2, but trying not to exaggerate ).
cholmes1
400lb Gorilla
350
216
Denver, CO
I see the rear beam replacement in favor of the tubing with tow hook, any cutting welding or just remove/install fasteners? I also like you brake cooling tube adaptors in the front bumper cover, what are those?
No welding is required for the beam and loops, but you do have to cut the bumper cover. You would also need to cut/modify the foam bumper backing if you want to keep it in the front.
The brake duct cooling is standard on the Laguna Seca. The OEM is 3” and I upgraded to the 302S/R 4” ducts. It requires removal of the windshield fluid bottle on the driver side and new 4” back backing plates. I got my ducts through Watson back when they existed for sale and the backing plate was from Fabman on TMO.
Thanks, the rear
Thanks, the rear tubular bumper beam looks good and solves the tow loop problem. This may make the winter project list.
There is a Roush lower driving light kit that has a molded trim piece requiring cutting away the bisecting horizontal trim bar making the lower opening plenty big enough to route a 4” adaptor and tubing. It may be more functional, bigger is always better?
cholmes1
400lb Gorilla
350
216
Denver, CO
@Boss4Me The rear bumper does not have a foam core support. It is simply plastic bumper cover and bolt-on rear beam. The DOT requires foam up front to meet pedestrian and low speed crash requirements. I scrapped my front foam before final mounting as it was more trouble than it was worth.
The front bumper beam is different. It has to be unbolted and cut off before you can mount the front bar. From the factory the front beam is spot welded and bolted in place. Depending upon the spot welding, you may have only a couple that can be easily broken by hand/pry bar, or, as in my case, it was nearly a full 1” bead weld above and below the frame mount that required both drilling and cutting to remove. An unexpected PITA.
All that to say, the rear tow beam was MUCH easier to install in my setup. The cutting of the bumper cover is more tedious than difficult. If you are not overly concerned about aesthetics it can be done quickly. I was very much concerned, so it took about two hours to get the holes just large enough for the female tow loop to pass through the plastic cover without a gap.
Brake ducts are a bit of a mix. I would certainly not say “bigger is always better.” I have many photos showing 302R/S race teams using bumper duct block off plates to keep some heat in the pads and rotors. The amount blocked off seems to be very track dependent. My car is used for occasional mountain road rallies (point-to-point) and a singular sprint event each year. Not road course racing. In my case the 302S/R 4” ducts are overkill and purely to add a piece of limited racing equipment to my car. They were not needed to address brake cooling issues. If anything, they often run too cool and I am working on blocking plates similar to the race teams. I also think the 302S ducts look better than the OEM 3” units.
Thank you for the questions, this is the motivation I need to put the steps and photos for both projects in my build thread
If more questions arise let me know. The tow beams can both be completed in a day. The ducts likely will require their own day depending upon your access to the underside. I have a lift so it only took a few hours.
Thanks for the detail on installation of the tubular pieces in place of the beams. The rear is going to make the winter project list, assuming Watson still has them in stack. For the front, I have a ZL1 Addon tow look. The offset from center is the negative, if I trailer the car a centered location would be preferred for a winch.
For my ‘14 GT project, I went down the path of attempting to replicate the ‘13 LS brake duct adaptors. The CS fog light trim part was simple OE online catalog part (thanks for the tip from another TMO’er). The unobtainable part is the bent metal/welded piece that attaches to the back of that trim part. After a few calls, Capaldi supplied that part to Ford for the factory throw-in LS brake kit. I talked with Leo and he could not find any remaining pieces. So I just dremeled an opening the GT trim insert attached a 3” adaptor from Allstar and called it functional, ugly but functional.
4
Los Angeles
Mostly, yes. They still make the MT82 shifter support bracket in addition to selling some NOS items from previous production runs. They can be found as user mustang-madness on eBay. As far as the topic of this thread, though, their tow hook set ups are probably knocked off the list as a contender unless you can find one second-hand.
For what it's worth, LMR seems to have begun selling what appears to be a direct copy of the Blowfish tow hook under the SVE name, minus the mount point for the plate holder, for the 10-14 cars.
