I always wanted to be able to jack my car up from one side in the middle, but the jacking plates I found were either not permanent or required welding them on to the car. I also wanted a plate that did not stick out much, so I came up with these. Still requires bolts to hold them on but the holes are drilled in the flange/pinch weld, not the rocker itself.
