S650 Time Attack Dark Horse
The stripes look great on your car and do post some more pictures if you have any? Welcome as a new member also.
I used a stock photo, I actually ordered with the stripe delete. Still waiting allocation but getting build kit ready to hopefully make some late spring-summer events.
i want to see what it can do at COTA showroom stock, then will add the Whipple etc to see where it's at before landing on classing and aero package but want to see how it can do near stock.
You will likely get plenty of folks on here suggest you forgo the Whipple and spend the funds on wheels , tires, suspension, harnesses, etc. as heat soak from a Supercharger is a real issue for road course machines. The extra work needed to keep it cool and work well for a decent period of time means you need to go in with the idea of spending more bucks to keep the motor cool. Many drivers will get vented hoods ( like Anderson Composites for example ) or cut vents in the hood to keep their NA motor in a good temperature range. Just a little advice of issues you will likely encounter and have fun at COTA.
