combination sub belt/lap belt mounts for S197
23
49
Canada
I currently have for sale one set of brand new design sub belt/lap belt mounts. These are very similar to my old sub belt mounts that I have made in the past but now have two tabs where the lap belts install. They mount just like old sub belt mounts, under the rear set mounts. You get a drivers side and passenger side mount along with new bolts to replace the factory studs and simple installation instructions. Cost is now $275 shipped. This is the only set I have for now but I can make more if needed. Here is what they look like.
And for those not familiar with how they mount, here is a pic of the new style mount installed in a Boss.
Hi I am new to this forum. I just got my 4-Point harness installed but I am concerned about the angle of my lap straps where the bracket is quite far behind the seat. I was also told that I cannot use a 5 point or 6 point harness with factory Recaro seats. This bracket looks like a better option than mine. I am not sure it will fit my 2022 Mach1 though? Can you share the distance of the floor mounting holes center to center on this bracket? I also question the tensile strength of this bracket?
You need these. https://trackmustangsonline.com/threads/fs-combo-lap-sub-belt-mounts-for-s550-and-gt350.13354/
And you can use a 6-point harness with your factory recaro seats. You use a sit on style sub belt. Not sure if I would use the bracket you are using.
8
7
Houston, TX
I'm interested in a set of your S197 6-point harness brackets for the stock Recaro driver and passenger seats in black. I don't have Paypal, but can send a bank check. Thanks!
