You can make the MT82 work pretty good if you spend enough money on it. Stuff like the Syncrotech carbon kit and some uprated gears, especially 3rd gear.
Then you need a rebuilder that can and will do work to precise tolerances, most trans guys won't spend the time on it, they just chuck it back together.
Then you need a good racing clutch.
Then pick your favorite secret sauce for fluid.
But most of all, you need a good trans cooler. I can't say that enough.
The bottom line is the MT82 is built on chinese engineering and labor and it costs money to fix that.
