- Thread starter
- #161
A few updates: Transmission fluid showed up in the same areas under the car again so I began to worry. I figured I'd see how much fluid I'm losing and top off the transmission. I pulled the fill plug and fluid started gushing out of the fill hole! Someone overfilled it by alot. So I drained it to the proper level, cleaned it up and I've been checking on it to see if more fluid shows up. So far it looks like crisis averted. So that's good.
Gear noise is still there. Nothing to say now except that must just be the AMP gearset. Shifter feels great. The poly transmission bushing didn't seem to be doing anything for my car except transmit noise. Things did feel more precise with the Blowfish bracket, but removing that didn't cause me any shifting problems either. And that thing caused a loud vibration. Update on my panhard bolt hole... Don't know what I thought I saw there but I went to take pictures for the guy I was going to use to weld, and I didn't see any damage at all. I must have seen it from a bad angle or something? Anyway, it looks like I'm good to go on that -- until I figure out that I was looking at the wrong hole or something.
And when I'm all ready to call it quits on my engine investigation and just live with it, I get an unexpected new data point that gives me one last hope of solving it. I'll go over the clues I have so far -- large and small. Been over the entire car multiple times at this point, so anything not mentioned has most likely been ruled out more than once. The transmission stuff appears to have been a red herring.
Now, I did try the valve seal angle previously by using seal conditioner, but that wouldn't help if there was a rip or if something wasn't seated right for another reason. I've read that valve seals can be replaced without removing the cylinder head, but every time I've asked someone about it, I was told that they wouldn't do it and that they'd pull the cylinder head for a rebuild instead if I really wanted to do that. Is that (replacing valve seals without removing the cylinder head) a really risky job? Because, to me, if I'm gonna pull the cylinder head, I might as well do the whole enchilada while we're in there considering the costs, and my car just doesn't need that yet. But if there's a cheaper way just to replace the seals, there might be a way to save this engine... get it in ship shape... and maybe one day even beat on it like it's meant to be beaten on...
- Shaun at AED says he can't tune me due to knock during WOT datalog. Datalog shows between 1-3 degrees knock starting at around 5k rpm. Happens at WOT only. Doesn't happen while daily driving. I've also taken the car to a local dyno tuner who also refused to tune the car.
- Long term fuel trims started off at around 19%, but after replacing the cracked intake tube, replacing the injectors, installing new plugs and some other things, I'm down to a high of around 11%, with averages around 8%.
- New Motorcraft spark plugs were installed at build time, 10K miles ago and when I pulled them out they were pretty dirty. Not ruined but lots of carbon. Replaced with new NGK iridiums.
- After finding the inside of my intake manifold caked with oil, I installed the FRPP oil separator on the passenger side. I've whittled my check intervals down to about once every 2k miles, and in that time I never find more than about 3 oz. of fluid, no matter whether I'm doing road trips, WOT datalogging or just driving around town.
- Ran a full battery of FDRS tests on the engine. Found cylinder 3 to have a slightly lower power output than the others, but still well within spec. Timing and everything else well within spec. Scoped cylinder 3 and found scoring. Not terrible scoring but does appear that it could impact on how the engine runs.
- Did compression and leakdown test. Results were very healthy, well within spec.
- I never see any blue smoke, but at cold start in the morning, the car does chug a little and there is a clear gasoline smell if I have the door open. I even tried setting a camera right next to the exhaust to record a cold start and I don't see anything unusual. After less than a minute, the engine is running normally and the smell is gone. OEM cats are still functional and are on the car, so light blue smoke might be being masked.
- Tried using some pretty aggressive seal conditioner (AT-205) with no solid results to report.
- Oil consumption has always been high. It varies anywhere between .2 qt. in 1k miles, to over a quart in 1k miles. Averages around 1/2 quart per 1k miles.
